I bought a 13" laptop to use with REW. After a measurement, I hit the capture icon (small camera) and it opens a box with settings. Unfortunately, the box is located a bit low on the screen so that the capture button at the bottom is hidden. So, each time, I have been stopping to move the box up a bit to expose the capture button. This is becoming tedious. Is there a way to either get REW to position that box higher on the screen, or should I just return the laptop and get one with a larger screen (does a larger screen help)? Are there other problems that are going to pop up with this smaller screen?
