best design for diy frameless acoustic panels an basstraps / an fabric for images
dreadknot
outlaw audio 976 7.2 balanced receviver
Crown xli 800 xls 1502
Crown xli 800 , Crown xli 800
crown xls 1502
nvidia shield (2017 model)
PL-89
PL-28II (for sale)
Klipsch RB-81 (sold)
Klipsch RB-81
none
none
none at the moment
none
none
Vizio M55-E0 (2017 model) upgrading to tcl 55in
none
none
none
none
none
what the best fabric option to use for diy acoustic panels an basstraps with images from
Design Fabric Printing
for my diy acoustic panels an basstraps
or from Contrado: Buy or Sell Artist Designs | Print on Demand
https://www.contrado.com/printing-on-florence-net-fabric
or the default
would either from this site work
my new acoustic tiles an traps are to be four custom 6in by 36in by 6ft frame-less traps two parallel to either side of the ht room
the plan is to get four six packs of roxul 80 an stack in a row of three deep by three tall after trimming them down to 2ft by 3ft an wrap the 6in thick perimeter in burlap an use duct butter on the burlap an roxul i think that will make it sturdy an rigid then wrap the whole with acoustic fabric
i also plan to some 60 x 10 x 3 mm Neodymium Bar Magnets stitched into the burlap in the back of the acoustic panels so as to adhere the panels to some painted metal strips on the wall which hopeful will allow for ease of placement an remove
would anchoring to just sheet rock with expander screws the total weight would be about 57 pounds
using 6 Neodymium Bar Magnets per tiles should give 72 pounds of pull does anyopne think this will work
or is this a crap shoot
one4
Yamaha CX-A5200
Monoprice Monolith 7X
Sony (Universal)
Magnepan MG12
Magnepan CC5
Magnepan MC1
Martin Logan Motion2
Polk RT90 & Acoustic Research AR4C (parallel)
Polk RT90
SVS SB3000 (Dual)
Furman SPR-20i; AC Infinity controller and fans
Samsung 4k UHD 65"
HP mini-destop PC
Qobuz
With the proper sheet rock anchors that should work. I've 150 lbs plus cabinets hanging on four 75 lbs anchors, Don't know about the magnets, but I don't see why not. Either way, it's the shear force and not the pull that matters.
Have you looked into these? https://www.primacoustic.com/paintables/#control-column
For your bass traps, because low frequency absorption, any covering will do... For your wide band absorbers any of the "acoustically transparent" coverings are fine... No need to get picky... Its what's inside that counts...
It might be helpful to have a look at some of the products at GIK, ATS or the others to see how their products are made and suggested placement...
Good luck with your project(s)...
