neodog
- May 3, 2024
- 26
- Computer Audio
- Focusrite Scarlett Solo
- Other Speakers
- ECM8000 mic
Does using a Loopback timing reference automatically compensate for the timing differences observed bout output and ref in a measurement?
If so, what is the effect of having both the loopback and the offset?
I got the above by using a loopback reference, and then using "Estimate IR" to update the standing offset for future measurements. Do the authorities fight with each other in establishing t=0, or does the loopback reference always win?
