Andrew Slater
- Jul 6, 2017
- 65
- toslink into Dirac Live box, & 3 minidsp 2X4 HDs
- Main Amp
- Focal 4 ch bridged to HLCDs
- Additional Amp
- 2 JL audio 600/4 bridged mid midbass
- Other Amp
- jl audio HD1200/1 Sub
- clairion NX706 96k Nav Screen
- HE Horns, Mids, Midbass bEYMA, b&C
Hi guys I have a sort of complicated question in regards to using rew and rephase together and making correction filters for left and right with unequal path lengths and in a tiny room with wheels and an engine.
Ive been using rew for a couple years now, getting to know a lot of the controls, wouldn’t say I’m a expert at any of them
My question is how to I get the left and right impulses to match each other so there’s no de-correlation from having to have different eq settings on left and right?
In rephase and in rew I can only do one channel at a time. If I apply the eq settings from let’s say left to both left and right the imaging is great. ( the path length differences have been corrected using signal delay on the near side)
I’ve tryed a few write ups on rephase to correct the system and make it minimum phase and that part sounds great now I’m starting to get the hang of it a little.
It would be so fantastic if there were two windows in rew and rephase for each channel and software somewhere within one of them that would warn you when the system will have imaging issues because of the use of independent eq.
Auto eq makes a great 1ch filter. It needs to do left and right and output a set of corrections that won’t de-correlate. Or if anyone can tell me how to do this.
Super awesome super appreciated
Andrew
Andrew
