ASIO device choice
zangaidaige
Hi
I try to test the result after I apply a filter in JRiver.
However I can't choose the input for my microphone.
Is it only available in pro version?
Thanks!
That's a limitation of ASIO, which only supports a single device for both input and output. You need to either use an ASIO wrapper like FlexASIO, which create a pseudo ASIO device that can have inputs and output from different devices, or switch to Java drivers and use the WASAPI Exclusive device entries (names starting EXCL).
zangaidaige
I tryed ASIO4ALL however the software just shut down after I click ASIO4ALL v2.
Is this issue caused by beta version 5.20.14?
zangaidaige
No, it is caused by ASIO4All. If you need to use an ASIO driver, use FlexASIO.
Yes I installed flexasio but There is no jriver option in device selection.
Maybe flexasio don't support jriver? Or is there another way to test filter performance?
