Audio_Guy_UofW
- Sep 2, 2020
- 54
- Denon AVR-4700
- Main Amp
- Neurochrome Modulus 686 for music
- Additional Amp
- Topping Pre90 preamp for music
- DAC
- SMSL M500
- Computer Audio
- Roon
- Panasonic DP UB-820; Oppo UDP-203
- Streaming Equipment
- Nvidia Shield Pro; Roopiee Raspberry Pi
- Streaming Subscriptions
- Tidal
- PSB Imagine X2T, Magnepan 1.7i (for music)
- Center Channel Speaker
- PSB Imagine XC
- Surround Speakers
- PSB Alpha
- Surround Back Speakers
- PSB Alpha Mini
- Front Height Speakers
- Totem KIN IC6 Slim (Front O/H)
- Rear Height Speakers
- Totem KIN IC6 Slim (Rear O/H))
- 4 sealed subs with 12" drivers custom built boxes
- Other Speakers
- Mini DSP 2x4 Balanced; HD Fury Diva; MSO sub tunin
- Screen
- EluneVision 96" Acoustically Transparent
- Video Display Device
- JVC DLA X500
- Remote Control
- Harmony Elite
- Other Equipment
- Thorens TD-160 Super, SME tonearm, Shure V15 IV with Jico SAS stylus, Arcam rPhono preamp
Hi
I am importing some measurement sweeps from a digital mic, so in dBFS. I want to use a measurement from a reference mic to correct these by removing the frequency irregularities of the stimulus speaker measured @ the test mic location.
In SPL measurements I can offset the reference mic measurement to 0dB @ 1kHz and use this curve to correct a measured response using the trace arithmetic |A|/|B| function. I want to do the same thing using dBFS measurements, however cannot figure out how to manipulate the dBFS curves to achieve the same result as I have with SPL traces...ie offset the reference mic dBFS curve to 0dB @ 1kHz and then use trace arithmetic to correct the dBFS test mic curve using this offset reference mic curve.
Is this possible in REW, or do I have to export for external manipulation?
