I'm just plain old stuck not having any luck sorting this out.
I want to use the RME UCX / Totalmix to sum a pair of QTC-1 mics for close speaker measurements -tweet and woofer on a two way cab.
I can route and sum the two mic inputs to a sub mix in Totalmix easy enough. But can't seem to find how I'd get that into REW's config. Can't REW see (or use) the software's paths as the mic's return input? (instead of just hardware I/O's?
I'm on V5.01 beta 20 build 3339 BTW..
And.. thank you for being here!
