Hi, I've got a friend who is looking to replace a cheap home theater setup in a small end of his basement (about 11x18). He wants to spend about $4-5k. He would rather buy fewer, quality components initially and add to it over time. I think he's interested in a 5.1.2 setup. My thoughts were:
So, what reactions do you have on this? Are there better options for the speaker vendor to go with? Thoughts on the trade-off of where the $ is going (e.g., spend less on a sub to leave more money for other elements?). Thanks!
- Buy a strong receiver that has a bit of expandability, but not too much beyond what he needs as this will already be a big step up. Dual zone support is needed as he wants to power a pair of existing speakers in another portion of the basement for music so should get 9.1 at minimum and could use some decent power as a result.
- Stick to speakers from a single, reliable vendor to make expansion and tone matching easier in the future.
- Start with a single, but quality Sub at first. Can add a 2nd later as desired.
- Use his existing cheaper speakers for height and surrounds initially. Can replace over time as desired.
- Receiver - Denon X3800H $1800 (though see note *** below)
- Subwoofer - SVS PB-2000 Pro $1200
- LR - SVS Ultra Evolution Bookshelf $1200 (600 x 2)
- C - SVS Ultra Evolution Center $800
- Total - $5k
- Later adds as desired in this order - new surrounds (pair SVS Prime satellite $400), new height speakers (pair Prime Elevation $450), a 2nd Sub ($1200)
