4 subwoofers, 2 amps, 1st REW
gadgetfreak
Spent 8hrs on this plus so far.. not sure i'm doing it right. But Here's where I'm at.
I have 4 subs total. 2 B&W CT SW12 up front powered by 1 SA1000 1,000W amp, and the same right above m haning above. So 2 subs up front powered by 1 amp, 2 subs in rear powered by 1 amp. I'm just running it out of mini dsp output 1 and 3
I followed the video in the setup post. I adjusted PEQ on input to take a few peaks and valleys as well. Here's what I got. would love any advice of what settings I should tweak. I'm a bit disappointed that this sub doens't go ver low. I am trying to get that chest hitting explosion, so seeing if I need to upgrade 2 of the subs or not.
would love to know if im doing this right.
Red is rear subs
Green is front
blue is after EQ measured.
I’m puzzled, the top graph shows a room curve, but the other does not. Is one of these combined response with all subs running simultaneously?
Your waterfall needs to be scaled for something like 35 dB – 90 dB.
BTW, that “chest hit” thing is up in the 60-70 Hz range, not 20 Hz...
