UMIK-1 USB Cable Recommendation
Allan S
Apex, NC
PS Audip Gain Cell DAC
PS Audio M1200
NAD T758
Philharmonic Audio BMR
Revel Concerta C10
Revel Concerta M8
Spatial Audio M4 Saphire
Bluesound Vault 2i
I just bought a USB C UMIK-1 but need a 15’ cable to reach the primary listening position. My preference is to buy a 15’ USB A / USB C cable but I’m not finding many options over 10’. Alternatively I could buy a 10’ USB A extension but would rather avoid the added connection if possible.
Any thoughts or recommendations for a cable would be most appreciated. Monoprice has a $2 extension but there’s something about plugging a $2 cable into a $100 mic that just seems wrong.
Thank you.
skid00
2 x Adcom GFA 555
Longer cables won't work, or will sporadic. I went back to a 6' cable. I use an MS Surface laptop PC, and put it on a stool, with the mic on a tripod, or hand-held.
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
I use my UMIK-1 with a buffered extension with no problems.
Allan S
Apex, NC
PS Audio M1200
NAD T758
Revel Concerta C10
Revel Concerta M8
Bluesound Vault 2i
Thank you. I’d got the same advice from Deer Creek Audio about longer cables an/or extensions. But I hadn‘t heard of a buffer cable before. I‘m going to need a lap top eventually anyway so may consider one sooner than later.
LCSeminole
Florida Panhandle
Emotiva RMC-1(DL v3.6.7)(7.4.4)
Emotiva XPA-7 Gen3
Emotiva PA-1 (x4)
Oppo UDP-203 / Panasonic DP-UB820
Arendal Sound 1723 Tower THX
Arendal Sound 1723 Center THX
Arendal Sound 1723 Bookshelf S THX
Arendal Sound 1723 Height S
PSA TV1813M(x2) / SVS PB12-Plus(x2)
Furman PL-PRO DMC 20A / Monster Power HTS-5000
Sony XR-77A80J (ISF Calibrated by ChadB)
Harmony Hub & Elite/665
AppleTV4K (2022)
Hulu Live TV / Disney+ / AppleTV+ / PrimeVideo
DSPeaker Anti-Mode 2.0 Dual Core
I've been using a 15ft USB A extension(pretty sure it was a Monoprice buy) for over four years now with my UMIK-1 that I bought from Cross Spectrum Labs. No problems what-so-ever.
