Suggestions for replacement drivers for M&K MX5000 Mk-II
pratul
Johns Creek GA
Anthem AVM 70
Anthem MCA 20
Anthem MCA 50
Monoprice Monolith 7x200
Oppo
M&K S-150 THX
M&K S-150 THX
M&K SS-150 THX
M&K SS-250 THX
Monoprice Caliber
Monoprice Caliber
JVC RS40U
Stewart 120" Greyhawk
ROKU Ultra2
Hello:
I replaced the foam ring on the original drivers when they wore out but the sub doesn't sound the same :( . It tends to clip/shudder when loud LFE play. I am now wondering if I can replace the drivers with something like "Dayton Audio UM12-22 12" Ultimax DVC Subwoofer 2 Ohms Per Coil" or Eminence Lab 12C High Power 12" Subwoofer Speaker Driver 4 Ohm. Would it work? Has anyone here done anything like this with good results?
The specs of the subwoofer are as follows:
POWER OUTPUT: 400 watts RMS
AMPLIFIER DISTORTION: Less than 0.03% from 20 to 125 Hz at full output into subwoofer drivers
INPUT IMPEDANCE: 15 Kohms
NOISE: better than -90 dB relative to full output
TYPICAL ROOM RESPONSE: 20 - 200 Hz ± 2 dB (THX position)
ANECHOIC RESPONSE. 18 - 125 Hz ± 2 dB (Anechoic position)
DIMENSIONS (H x W x D): 23 1/4" x 15 1/2" x 26" (MX-5000 Mk II)
WEIGHT: 105 lbs.
The sub is a push-pull design and uses two 12", 4-ohm drivers.
What do you guys think? Doable?
Thanks!
Have you checked with M&K about replacement drivers?
Otherwise I think it might be difficult to find drivers with the correct parameters to match up, so you may not know what you are getting in that box of chocolates.
pratul
Johns Creek GA
Anthem AVM 70
Anthem MCA 20
Anthem MCA 50
Oppo
M&K S-150 THX
M&K S-150 THX
M&K SS-150 THX
M&K SS-250 THX
Monoprice Caliber
Monoprice Caliber
JVC RS40U
ROKU Ultra2
I tried but got no response from them :(
Reach out to Ken Kreisel and see if he has any suggestions, or perhaps he could design you one... he'd likely know.
pratul
Johns Creek GA
Anthem AVM 70
Anthem MCA 20
Anthem MCA 50
Oppo
M&K S-150 THX
M&K S-150 THX
M&K SS-150 THX
M&K SS-250 THX
Monoprice Caliber
Monoprice Caliber
JVC RS40U
ROKU Ultra2
I had seen you had suggest the same to someone else some time back. I sent Ken an email a few months back but he did not reply. I sent him one just now. Hope he replies.
I hear a lot of good things about SVS and have been looking into them as well. If I can't find a way to repair the ones I have I might add a couple of SVS subs. I contacted them and they suggested supplementing them with PB-1000 Pros since they are close to the power output of my current subs and are also ported. Although, I think the MX5000s are closer to a sealed sub as they employ the push-pull design.
decisions, decisions... :)
