Need help with Sony's XBR65X900F
JimShaw
Active Member
Menifee, CA
Denon X7200WA
Oppo UHD-203
SpeakerCraft Aim8 Fives
(Wides) SpeakerCraft Time5
SVS PB13-Ultra
(Two) HSU MBM-12 MK2
Sony XBR-75Z9D and LG OLED55E6P
Harmony 1100 and Harmony Elite
My neighbor's Sony XBR65X900F has been fantastic for my 80+ year old neighbors
But that changed a couple days...
The TV's standard remote is used. When the remote's volume buttons are use, the TV's audio goes up or down as per the button being used on the remote ALONG with the TV's volume display that pops up on the screen
Something happed a couple days ago and I cannot find the reason by going into the TV's settings.
The remote's volume buttons still work the TV's volume slider display BUT...
...The TV's audio no longer goes up or down while using the remote volume buttons. The TV's speakers work but the volume of the audio no longer goes up or down. It seems stuck.
Anyone know why the TV's audio no longer goes up or down when using remote??
skid00
2 x Adcom GFA 555
I have a similar Sony, and had problems with sound output to Bluetooth and a soundbar.
I had to load a newer version of the TV's O.S. to fix the problems. The Sony site will have downloads, you put them on a USB stick. There's USB inputs on the back of the TV. The TV will prompt you when you insert the stick.
