Auto eq (MINIDSP 2x4HD) with smaart IR
Andrew Slater
toslink into Dirac Live box, & 3 minidsp 2X4 HDs
Focal 4 ch bridged to HLCDs
2 JL audio 600/4 bridged mid midbass
jl audio HD1200/1 Sub
clairion NX706 96k Nav Screen
HE Horns, Mids, Midbass bEYMA, b&C
Hello
I imported some transfer function averages from smaart into REW for auto eq
With rephase eq using auto eq the result is a dead match!
With 2x4hd eq and auto eq it’s not so good…
Why?
What am I doing wrong?
Any ideas much appreciated…
You haven't give us much to go on, the mdat file and your target match settings would be helpful. The rePhase eq setting allows 17 filters, the 2x4HD allows 10, so that's one difference.
