2020 Lexus ES350 Moonbeam Me Up SQ Build
I suppose my wife got tired of me trading every year or two and decided it was time to have her a new ride... after all, she's had her 2013 EX350 since 2013 and it over 100,000 miles. She grabbed her a 2020 ES350 in the Moonbeam Beige color. Several of you already know from my previous build threads (even a few of you heard it) that Steve Cook at AudioX in Florence, AL installed the system in her 2013, and it sounded marvelous to say the least... and it should considering Steve's credentials and what he's done nationally in SQ competitions over the years. The 2020 has a Pioneer system that actually sounds fairly decent up front when you crank it on up, as long as you don't care for much bass. Either way, it won't please her, as she is spoiled about as bad as I am when it comes to car audio sound. So the fun begins.
She will get some of my system in my 2020 RAM, consisting of the HAT Unity 6x9 door speakers, the Legatia X3-P dash speakers and the miniDSP CDSP 8x12 DL processor, and likely my JL Audio XD600/6. I plan to use the sub box and JL Audio 10W6v3 subwoofer, and the XD600/1 amp from the 2013. I've spent the last couple of days tearing out most of that system and reconnecting the factory system so we can get the car ready to sell. I'll probably use the rear door speakers for rear fill. The amps will mount on a custom built rack similar to what Steve did previously, but modified due to the fact the trunk height in the 2020 is about 1.5" less than the 2013, so his setup won't quite fit. It should be easy to modify, and the miniDSP processor is considerably smaller than the Zapco DSP. In case you are wondering, I'm going back to factory in my RAM with some upgraded speakers up front, and keeping the Stealthbox for the subs. Yep... sacrificing for the wife, at least for a little while. :whistling:
I've started tearing the 2020 down... beginning with the front left door so that I can treat the doors with dampening and closed cell foam. At first look, the door speakers appear to be a decent 7" speaker, but after removal, it is clear there is not much going on with it. The hole in this door is huge, so there will be no issue fitting the HAT Unity 6x9 speakers from my truck with a custom mounting plate. I've used this speaker in a couple of systems and they are very capable.
34476
34477
34478
Lexus did splurge on the dampening material... one 4 inch square piece behind the speaker on each door. Not sure what they thought that would accomplish.
More to come!
Tearing it down...
34479
34480
34481
34482
34483
Door speaker on left... dash and center channel in the middle... factory sub on the right. I did not know they made speakers in Vietnam.
My covey hole... need to better organize and clean up a bit... got too much going on.
34503
I have always been curious if there is really anything to breaking up the back waves of a speaker. I had some closed cell acoustic foam, so figured I would try it, but I have no idea how you'd know if it's working or not.
34504
Trying to get at least 50-50% coverage, so adding to what Lexus has already done. Banging on areas to find anything the might vibrate. That metal brace going across the opening behind the back seat was making some serious noise for sure. Wheel wells are in pretty good shape, but the side panels did need a little more dampening. Also got a good bit of the rear deck taken care of... and the truck lid was extremely resonate, so I took care of it as well.
34505
34506
Next is the Ensolite on the door panels and inner door skin to eliminate any rattles and also help with road noise. Tracing out the door panels. I cut one out for the rear doors, flip it and cut another, then cut two more copies of those... then do the same for the front door.
34507
34508
Next up is the mounting bracket for the front door speakers... needs to be about 1/2" to clear the window, so I used some 1/2" ABS that I had... worked perfectly.
34509
34510
34511
Treatment is all done, and front door speakers mounted, covers back on... ready to tackle the front dash speakers next.
tripplej
NAD T-777
Oppo 103 Blu Ray Player
2 Paradigm SE Subs
Nintendo Wii U Gaming Console
Samsung UN75F8000 LED TV
Universal Remote MX-450
Wow, very impressive. Great job. :)
Thanks... I love doing this stuff, although I wouldn't want to do it for a living.
Got the mounting brackets finished for the front dash speakers and they are now installed. Everything fit as it should... huge factory 10mm machine screws/bolts over an inch long anchoring the dash speakers. They meant for them to stay around I suppose.
34521
34522
34523
Hope to start on the trunk tomorrow.
Got the power wire ran from the battery to the back... had to cross over to the passenger side to get to a rubber grommet in the firewall. That will also keep the power wire running down one side and the signal wires running down the other, since the factory amp is under the front driver's seat.
34560
Finished up the LC6i install under the front seat and all wires tucked away to the back.
34619
Bass knob to control the sub...
34620
Started on the trunk ... using the sub box that Steve Cook built for the 2013 install. It's still in great shape and it's 1 inch MDF. I did recover it.
34621
34622
Finished the cover today... and got a good bit of wiring done as well. I hope to finish up tomorrow so that I can begin tuning on Monday.
And she's done... tuned and ready to rock!
34709
tripplej
NAD T-777
2 Paradigm SE Subs
Wow, very nice. Congrats! :)
