Wireless Subwoofer
whoareyou
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
If anyone using wireless subwoofer, how is it working out for you with AL measurements?
jrobbins50
I’m not using wireless for a subwoofer just now, but I have in the past and had no issues with ALXO to do so. JCR
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
Mac mini and IMac 27
ExaSound S88
VPI Prime turntable
Custom open baffle 3 way
Velodyne DD12+
Roon
Roon Quobuz
Yes on two small systems with LS-50 wireless II. bought two wireless transmitter receiver kits. Everything works well. The key is to determine the delay to the subwoofer which is long because of the wireless transmission of the sub signal. Then have Audiolense align all the drives to the slowest driver ( subwoofer)
it works great !
whoareyou
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
it works great !
So, you're saying just take measurement with AL as usual, correct?
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Velodyne DD12+
Roon
Roon Quobuz
Yes, because the impulse response is going to be off by quite a bit, manually move them closer together
Ofer
miniDSP 4x10hd
Emotiva XPR200 midrange amp
Rotel RA930ax twitter amp
Sony Bravia android TV
RME UC
Marantz original 5E CD
Andromeda MkII
Sony bravia 65XF9005
Deezer HiFi
How do you place the mic? facing the ceiling? I am considering putting a wireless kit on one of my powered sub and place it in behind the LP. What kits did you use? is it BT or WiFi based?
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Velodyne DD12+
Roon
Roon Quobuz
Ofer
miniDSP 4x10hd
RME UC
Andromeda MkII
Deezer HiFi
Ofer
miniDSP 4x10hd
RME UC
Andromeda MkII
Deezer HiFi
Bump. The mic direction is not clear to me. If anyone did it I would be happy to understand.
juicehifi
Audiolense
The mic direction probably doesnt matter for a sub. The mic will be omnidirectional at such low frequencies.
Ofer
miniDSP 4x10hd
RME UC
Andromeda MkII
Deezer HiFi
So even if the mic is pointing toward the front speakers and the sub is behind it timing will be calculated correctly?
Ofer
miniDSP 4x10hd
RME UC
Andromeda MkII
Deezer HiFi
Another question. Does the sub definition in the speaker tab of the speaker setup effects the was AL measures or processes the measurements? Does it matter downstream if one chooses "subwoofer front right" or "subwoofer back right" to measurements or filter generation or is it just semantics?
