Using Multiple Audio Formats and Audyssey?
phillihp23
Washington, The West
I setup my AVR with speakers and amp assigned for atmos 7.4.6 and used audyssey eq.
If I switch my speaker layout and amp assign too 9.4.2 for a movie what happens to my audyssey eq.?
Kal Rubinson
Active Member
NYC
There will be no AudysseyEQ since it is based on a fixed speaker configuration. Some prepros will store more than one configuration/EQ but I do not know if yours does.
phillihp23
If it doesn’t is there a device that would, that I can hook up in my system chain?
On further review I found this in the AVR manual. If it can detect format and choose what 13 speakers to output audio of the 15 connected then wouldn’t audessey be eq’ing all 15 when it is run?
Kal Rubinson
Active Member
NYC
Not that I know of.
Only if you never change the configuration.
