USE of REW RTA for engineering applications
men5j2s
denon AVR-X 1000
B&W 685 S2
B&W HTM6 S2
Cambridge Audio Minx 12
B&W PV1 D
Loewe Art 50
Loewe Assist
Hi all,
I'm a mechanical engineer looking to do some acoustic analysis of a small device.
I cant declare what it is that I am working on due to confidentiality, but I have a pretty solid analogy for it.
Imagine a train conductors whistle, which has a cork ball in it to create that signature oscillating sound that the Acme thunderer has (google it if you don't know).
I have a vacuum pump applying constant suction to the whistle at different flow rates (tunable by me); the vacuum pump sounds like a traditional hoover (because that's where I got the motor from).
So... here's my problem...
I want to try to quantify the frequency of the oscillation of the cork ball in the whistle - or at the very least, be able to discern if it is or isn't oscillating, and perhaps some measure of its intensity.
The vacuum motor is very close and hence there is a lot of background noise, but I know for sure that when I get the oscillation there is a new peak at around 11KHz, that changes in shape dependent on the speed of the oscillation. but how can I use REW to remove that vacuum noise?
I could do a recording for a minute at a time for example and take averages, or whatever it takes, but I've never really used this kit before or done any type of serious spectral analysis.
P.S I'm using a Dayton Audio UMM 6 mic with the calibration file.
Any and all help is welcome and appreciated, but please keep it simple for me :)
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
Keep in mind that REW is merely a measurement platform. It can’t “remove” any acoustical signal. REW could help you identify the frequency of the oscillation of the cork ball, if it is sufficiently above the noise floor you mentioned.
