Does Changing An Amplifier Mean I Have To Remeasure Everything?
Trdat
I might, switch my amp to my mid woofer(midrange) in my tri-amp system from a Hypex NC502MP to a NC122MP in BTL. Does that have detrimental affect on impulse repsonse or group delay or any other factor inlfuencing sound?
Regarding gain, I am not too fussed as I often switch the gain from the minidsp volume control depending on the genre of music.
Trdat
My limited understanding is that with the Hypex amplifiers in BTL you have to invert one side of the wiring which will put the two amplifier channels out of phase. Does this mean that my woofers will be out of phase?
juicehifi
Audiolense
No need to remeasure with these amps. Only needed if you switch between amps that adds coloration.
Trdat
Yes, these amps are tranparent. I just thought the phase maybe played a role when switching to BTL mode....
Thanks.... This is good news.
Trdat
My apologies just read the spec sheet and apparently the phase doesn't change in BTL mode...
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
Mac mini and IMac 27
ExaSound S88
VPI Prime turntable
Custom open baffle 3 way
Velodyne DD12+
Roon
Roon Quobuz
I would check the spec sheet and determine if the amplifiers gain is the same between your existing amp and the new model. If there is a gain difference you need to retest.
