Window markers at Impulse
bobolix
It would ve extremely useful if the markers for window (Left, Ref, Right) would be visible and functional at the Impulse mode with Offset t=0 activated (now they are not and the window parameters need to be set numerically in the IR Windows panel, which is quite inconvenient.
bobolix
Thank you very much ! I work a lot with window boundaries to be able to adjust the phase response in slightly noisy conditions, which is very sensitive to window settings. I note that the numerical setting is actually stepped by 10 us, which is surprisingly quite coarse (in fact it is a step corresponding to approximately one sample at 96 kHz sampling, but REW works at the fractional level in some cases).
bobolix
These are the visualisations of the high-end loudspeaker prototypes I'm working on recently:
The arrow buttons on the spinner change it in 10 us steps, but values with 1 us precision can be typed and fine adjustments can be made by zooming in and dragging the time axis.
