Why HDMI ARC is Not An Audiophile Solution
Bob Rapoport
Music Reviewer
Essence HDACC II-4K
Essence DPA-440
Sony 4K
Essence Electrostats
Essence
Essence
Essence
Screen Goo painted screen, 4 coats
Vizio M70
Essence
In recent years, television manufacturers have promoted HDMI ARC (Audio Return Channel) as a convenient way to connect TVs to external audio systems. For the average consumer using a soundbar, it does the job: a single HDMI cable carries the video source to the TV while the audio is “returned” to your audio system.. But for serious music lovers and home theater enthusiasts, HDMI ARC is not an audiophile method of adopting HDMI sources. Here’s why.
1. Making the TV the System Hub — A Fundamental Mis-step
ARC flips the traditional audio chain on its head by making the TV the main hub of the system. That means your carefully chosen source devices — Blu-ray players, Apple TV, Roku, game consoles — all feed the TV first. From there, the TV’s built-in circuitry controls the audio signal that is returned to your audio system from the HDMI ARC output. Unfortunately, TVs are not designed to handle audio at high fidelity standards. Their primary job is video, and when it comes to audio, their design is optimized for convenience and soundbars, not true high-end reproduction.
2. Reliance on TV Apps and Volume Control
ARC ties you into the TV’s internal apps for streaming (Netflix, Prime Video, Disney+, etc.) and its volume control system. Neither of these was engineered to satisfy audiophile expectations. The apps are often compressed, inconsistent, and updated for speed rather than sound quality. The TV’s internal volume control, meanwhile, was designed for built-in speakers or a midrange soundbar — never for a precision preamp stage. You’re essentially asking a TV to do what an audiophile DAC or preamp does with infinitely more care.
3. Lip Sync Problems
Another overlooked drawback is lip sync error. With ARC, the video signal has already been processed and displayed by the TV before the audio is sent back upstream to your audio system. That delay creates the classic problem of sound trailing behind the picture — breaking immersion and undermining the precision that serious listeners demand. Audiophiles spend decades chasing millisecond-level timing perfection; ARC undermines it at the most basic level.
4. The Proper Audiophile Chain
The traditional audiophile way is to put the source devices upstream — routing them directly into an AVR (audio/video receiver) or into a high-performance DAC/preamp. This ensures the highest fidelity audio extraction before any video processing occurs, maintaining perfect sync and uncompromised sound. The Essence HDACC II-4K was designed precisely for this purpose. With HDMI inputs and outputs, it preserves the integrity of the original digital content, converts it to the purest possible analog, and passes video through to the display untouched. It aligns with the audiophile tradition — source first, preamp second, speakers last.
Conclusion
HDMI ARC may be fine for casual viewers and soundbar users, but it’s no substitute for a true audiophile system design. By making the TV the audio hub, it introduces compromises in fidelity (it's bandwidth restricted to below Hi Res Audio standards), sync, and control that no serious listener should accept. For those who demand the best from their HDMI sources, products like the Essence HDACC II-4K — and traditional AVRs — keep the audio chain intact, the way high-end playback was meant to be.
I have everything connected to the amp, watching netflix, prime etc throught the Appletv 4k box, also connected to the amp :T
Doing things the traditional way delivers the optimal viewing and listening experience. Glad to hear it Gerry.
Totally agree with your point 4 @Bob Rapoport... And have always used an AVR for a "hub" in an A/V solution...
ARC is definitely a secondary option when viewed through these points. I guess I've always thought of it as a convenient soundbar hook-up, that, in its very nature, is compromised. But, if you're dumping back to an AVR and distributing audio to a larger system, then it's definitely sub-optimal.
Great points, Bob! I especially appreciate #2!
Yes concur with your ARC thoughts Bob. I am forced to use it currently after buying an Eversolo A8 which only has ARC in. I queried them but they chose not to use standard HDMI input. I guess ARC suits most people generally and is the future.
Unfortunately my newish Sony 77" Oled can only process audio to 48khz(output) from all inputs regardless of input bit rate (anything up to 24/192 is reduced to 48). I'm inputting an Nvidia Pro shield and Oppo 205. The Sony is primarily only used for picture. In the future I guess TV manufacturers will allow processing up to 24/192 to be output ARC.
I do have an older Kanex extractor which does work well for the Oppo 205 HDMI audio output for both SACD's and video's.
Unfortunately shipping cost is high to New Zealand, half the value of the HDACC II 4k.
I'm only interested in 2 HDMI inputs, 1 HDMI output, 1 Coax output, 4k 60hz video pass through and audio extraction up to 24/192. Is this possible?
Robert
Robert
Hi Robert, yes the HDACC II-4K supports up to 4 original HDMI inputs with one HDMI output to feed the TV, has both Coax and Optical in/outs, supports 4K 60 Hz video pass through and audio extraction up to 24 / 192K. Shipping cost to New Zealand by US Postal Service Priority International with tracking and insurance is $96.45. It fully supports DSD files on SACD up to 256 via HDMI from your Oppo. HDMI ARC is bandwidth restricted to below Hi Res Audio standards too, another reason to avoid it. Here's a link to some User Testimonials that will give you greater insight. https://www.essenceelectrostatic.com/wp-content/uploads/2025/03/User-Experiences.pdf
The Nvidia Shield and the Oppo will sound and look better going through the HDACC II-4K, its a real high performance DAC. THD + N = .00001% at -141 dB SNR.
Thanks for sharing your thoughts Todd, ARC is also bandwidth restricted to below Hi Res Audio standards, another reason to be avoided in high performance systems.
