FargateOne
- Jun 5, 2017
- Messages
- 223
- Rotel RSX-1562
- Additional Amp
- Bryston 3B3 for fronts mains
- Cambridge CXU
- B&W 804 D2
- Center Channel Speaker
- B&W HTM4D2
- Surround Speakers
- B&W 705
- SVS PC-2000 and SVS PC-2000 Pro
- Other Speakers or Equipment
- 10 PEQ filters/channel in receiver with REW
- Video Display Device
- Samsung UN55ES8000
- Other Equipment
- miniDSP 2x4 HD
Hi,
Rotel receiver RSX-1562 enable us to manually eq each channels. I think that all Rotel receivers and pre-amp has this possibility because no Rotel products come with a built-in PEQ like Audyssey Dirac or YPAO for instance.
Here are the specifications we have:
BAND 1 Freq : 20Hz - 80Hz, 1Hz Step Default 40 Hz
BAND 2 Freq: 20Hz - 80Hz, 1Hz Step Default 60 Hz
BAND 3 Freq: 81Hz - 140Hz, 1Hz Step Default 100 Hz
BAND 4 Freq: 81Hz - 140Hz, 1Hz Step Default 120 Hz
BAND 5 Freq: 141Hz - 200Hz, 1Hz Step Default 160 Hz
BAND 6 Freq: 1110Hz - 1550 Hz, 10Hz Step Default 1300 Hz
BAND 7 Freq: 1560Hz - 2000 Hz, 10Hz Step Default 1750 Hz
BAND 8 Freq: 2.1kHz - 8kHz, 100Hz Step Default 4k Hz
BAND 9 Freq: 8.1kHz - 14kHz, 100Hz Step Default 10k Hz
BAND 10 Freq: 14.1kHz - 20kHz, 100Hz Step Default 16k Hz
Q : 1 - 24
Gain : -12dB - 0 - +3dB
I thought that MiniDsp would work for the sub channel and NanoAvr for the speakers? I am not sure to get the best results even with the "generic".
Since Dual core has been added I risk to ask if it could be possible (complicated) to add Rotel in REW?
Q : 1 - 24
