I may be the only one who has used the virtual balanced input as a means to improve measured noise and distortion in an audio interface or amp, but it worked when using the Delta 1010LT, even with the balanced inputs. I suspect that is due to the card having both balanced and unbalanced inputs. REW may be sensing that the 2i2 has no unbalanced inputs, therefore the virtual balanced input option is disabled. What I want to do is use that option in sum mode to combine the two inputs with a splitter sending the same signal to both channels. The sum mode sums the two, then divides by 0.5, exactly what makes it work for the distortion calculations.
Edit: I just found that using the Input Selection Dialog in the RTA will allow setting the Balanced option, but that does not change the option status in Preferences.
And now I see that it has the option for Separate cal for each input. I'll experiment with that, but it took some digging to find that. I had been trying only the Preferences screen. And it still not possible to change the Virtual option from diff to sum.
It would be handy to have an option in the Scope Channel settings screen to call up the Input Selection popup directly.
