Using REW with USB output to external DAC
Marco Stanzani
AM Audio A100M
Rotel
Quad 405-2
Oppo BDP-105D
Dynaudo BM15A, B&W 801F
Dynaudio Countour Center
Dynaudio BM5A
Dynaudio BM9S
JVC DLA X-70
Adeo 16/9 tensioned, motor
Hello
I am starting to use REW in those days and after extensive readings all around - the REW help and the Getting Started with REW: A Step-by-Step Guide (Rev 5.43, June 3, 2017). I came to the point to submit the following point of discussion. I am planning to use REW with an UMIK mic connected to the USB-in of my HTPC. The HTPC is connected to a Teac UD-503 USB Stereo DAC. The step-by-Step Guide extensively explain how to deal with a mch receiver connected to the HDMI output of the PC, which is not my case. I am looking for suggestion hints related to my case.
I am sorry if this has been discussed already (which I did not find
Thanks much
Marco
Shouldn't be much different, select the DAC as your output device and output in REW and that should be it.
Marco Stanzani
AM Audio A100M
Rotel
Quad 405-2
Oppo BDP-105D
Dynaudio BM5A
Dynaudio BM9S
JVC DLA X-70
Thank you. My concern was about REW being able to control the volume of the audio output
kind regards
If Windows is able to control output volume REW should be, as long as in the REW soundcard preferences the output is selected (not left as default) and the box is ticked to allow REW to control it.
