Bob Rapoport
Music Reviewer
- Jan 29, 2018
- 146
- Essence HDACC II-4K
- Main Amp
- Essence DPA-440
- Sony 4K
- Essence Electrostats
- Center Channel Speaker
- Essence
- Surround Speakers
- Essence
- Essence
- Screen
- Screen Goo painted screen, 4 coats
- Video Display Device
- Vizio M70
- Remote Control
- Essence
t
When two of the largest and most advanced AI platforms in the world — ChatGPT and Google’s Gemini — independently evaluate an entire product category and both arrive at the same #1 recommendation, that’s worth paying attention to.
For enthusiasts who own cherished vintage amplifiers, preamps, receivers, or powered speakers and want to integrate them with today’s 4K sources (Apple TV 4K, Panasonic UHD Blu-ray, Roku Ultra, game consoles, etc.), the conclusion from both AI systems is clear:
The Essence HDACC II-4K stands alone as the best-in-class solution for bridging HDMI 4K to legacy two-channel audio systems without compromising video performance or audio fidelity.
Why Both AI Platforms Ranked It #1
1. True HDMI Input and HDMI Output — No Compromise
Every AI system that evaluates signal flow comes to the same unavoidable conclusion:A device must have HDMI input and HDMI output to preserve 4K UHD video untouched while extracting hi-res audio.
Most DACs in this category don’t do this.
They rely on ARC, which has three fatal flaws
- Low bitrate
- Low sample rate
- Only 2-channel output
Gemini’s wording summarized it perfectly:
“The HDACC II-4K extracts high-resolution audio while sending untouched 4K video to the TV, ensuring seamless integration and avoiding video lag.”
2. Vintage Audio Gear Finally Gets the High-Resolution Feed It Deserves
Owners of McIntosh, Marantz, SAE, Audio Research, Nelson Pass designs, and other legacy classics consistently report the same jaw-dropping experience:Both AI platforms highlighted this exact feedback as evidence that the HDACC II-4K is solving a problem nobody else solved correctly.
“It lifted a veil.”
“Like hearing my system for the first time again.”
“A miracle box for vintage audio.”
The reason is simple:
Vintage gear has superb analog stages, but no HDMI. Once you feed them hi-res PCM extracted from a 4K source before the TV downsamples it, they finally show what they’re capable of.
3. ESS Sabre DAC, XLR + RCA Outputs, and Ultra-Low Distortion, ChatGPT and Gemini both noted the extreme technical strengths:
- ESS Sabre DAC architecture
- XLR + RCA outputs for any stereo system
- THD+N of just 0.00001%
- SNR of –141 dB
- 32-bit / 384 kHz PCM capability
No AV receiver in this price range — or even several times the price — offers this level of DAC performance.
And unlike AVRs, the HDACC II-4K does not touch the video and does not re-clock or transcode the signal. It simply passes 18 Gbps UHD 4K/60 as-is.
What Google Gemini Said (Excerpt)
Gemini’s credibility isn’t just AI — it’s Google!
“For integrating modern HDMI 4K AV sources with vintage audio gear, the Essence HDACC II-4K is the top-rated #1 pick.
It is highly recommended for its purpose-built HDMI inputs, 4K video passthrough, and high-performance analog outputs…
Reviewers praise it as a ‘miracle box’ for anyone wanting to use their vintage receivers with today’s 4K streaming sources like Apple TV 4K.”
Most people don’t yet know what Gemini is… but everyone knows what Google is.
What ChatGPT Said (Excerpt)
Two independent AI systems, both analyzing the same category, both using massive datasets, and both arriving at the same top pick — it’s a milestone.
“The HDACC II-4K remains the definitive solution for connecting modern 4K HDMI sources to classic stereo systems with better performance than any alternative in its class…The competitors require ARC and sacrifice resolution, dynamics, and fidelity.”
Why This Matters to Audiophiles
Because the industry has moved to HDMI 4K/8K for video and audio delivery, vintage systems were being left behind — until now.Every other approach is a compromise:
| Method | Audio Quality | Video Quality | Problem |
| HDMI ARC to a DAC | Low bitrate, low sample rate | None, ARC is audio only | Only 2-ch, compressed return channel |
| AVR as a middleman | Weak DAC performance | Video may be reprocessed | Bulky, noisy, expensive, unnecessary |
| Optical/Toslink from TV | Heavily downsampled | No video over SPDIF | TV becomes system hub; limited formats |
| DACs with ARC only (no HDMI out) | Must route video separately | No unified HDMI chain | Far from optimal |
The HDACC II-4K solves the entire chain with one requirement:
Place the DAC upstream — between the source and the TV — where all the full-resolution audio lives.
This is the method both AI platforms endorsed.
Final Thoughts
When you design a product that hits the signal path exactly right —the engineering, the workflow, the problem-solving — it resonates.
This month, it resonated with
- ChatGPT (OpenAI) — the largest conversational AI platform in the world
- Google Gemini — the world’s most advanced multimodal AI system
For a small boutique company like Essence, this is a remarkable validation — not from a marketing department, not from a reviewer, but from two global supercomputers trained on the entire internet.
And more importantly:
It’s validation for every audiophile who believes that great vintage & legacy gear still deserves the very best digital content available today.
For more information, contact Essence CEO Bob Rapoport at bob@essenceelectrostatic.com
