First, a huge thanks to John for making this wonderful software available to us.
This is my first time doing this. I've got the UR22C connected to a Macbook Pro M1 and am using a NAD class AB amp with a voltage divider as in the following thread except with 47K and 22K resistors and a 9.6R sense resistor.
I can't post links so had to do this
I've got 2 questions.
1. As per post #8 of the thread John says the only calibration required is the Impedance calibration. However the Impedance measurement screen has a place to upload Cal files for the UR22C. So am confused.
2. If I should, the sound card calibration step suggests to route the Output of the interface back to the Input. How is this to be done when using an amp and a voltage divider network?
3. I just skipped the sound card calibration and moved on to the open circuit calibration but I get the following warning with a 96KHz sample rate. (Midi rate also set to 96Khz)
What could be causing this? If I move up to 192Khz I get an offset of 1+ samples and REW says it can't use that measurement.
If I proceed with the short circuit and reference calibration I get the following measurements. Does this look ok?
Open Circuit...
Short circuit...
Reference cal with 32.2R resistor...
Thanks!
Code:
https://www.avnirvana.com/threads/sound-card-calibration-and-impedance-circuit.6810/
Open Circuit...
Short circuit...
Thanks!
