Thiele & Small Measurement problem
Jon411819
Trying to measure Thiele & Small parameters but when I open the Thiele & Small measurement tool it won't allow me to select a measurement from the dropdown menu. Not sure if I have missed something obvious or not. I have read the help guide but still cannot get it to work? Any suggestions? Thanks for your time.
Only impedance measurements appear in the selection list for TS, do you have impedance measurements loaded? Need to make the impedance measurements first (select Impedance on the Measure dialog) then select them in the TS tool afterwards for analysis.
