Erin
- Denon X4000, Rane RPM88, MiniDSP DRC-88A
- Main Amp
- Crown Amplifiers XLS1502 x3 (front L/C/R)
- Additional Amp
- Crown XLS2502 (Subwoofers)
- Oppo BDP-103
- DIY JBL Pro (2446j CD, 2380A horn, 2035HPL 15's)
- Center Channel Speaker
- see above
- DIY SI HT18 in 4cuft ~18Hz
- Video Display Device
- Sony HW-55ES
- Screen
- DIY 120" Acoustically Transparent
Up for test is the SVS PB-2000 Pro Subwoofer.
In this video I break down the features and discuss the objective performance of the SVS PB-2000 Pro. I have taken the liberty to provide an overlay of a comparison against the Monoprice Monolith THX 12 (in ported mode, THX EQ) because I have gotten many questions regarding how the two compare. In a nutshell, the two are pretty closely matched with the edge going toward the Monolith in terms of response linearity and max SPL per the CEA-2010-A/B standards. However, the SVS provides built-in Bluetooth connection for settings controls in addition to those found on the back. Additionally, with the BT app you can also access 3 bands of P-EQ which, IMHO, is a notable feature and may be a deciding factor for some.
You can find the CEA-2010 test results spreadsheet here:
https://docs.google.com/spreadsheets/d/18bz7z-xIlRJsC-bw6k4mHkuwv_uiGAMyEhgrTkjwdXc/edit?usp=sharing
Hopefully you find something useful in here.
Let me know if you have any questions.
- Erin
- Erin
