Slash
- Feb 15, 2018
- Messages
- 2
- Marantz 8802
- Main Amp
- Cinepro 2K5
- Additional Amp
- Emotiva XPA-2
- Other Amp
- Samson S700
- PS3
- CLD Dynamics
- Center Channel Speaker
- CLD Dynamics
- Surround Speakers
- Swan Diva 5.1
- Surround Back Speakers
- Swan Diva 2.1
- SVS 20-39 x2
- Video Display Device
- JVC RS500
- Screen
- Stewart 110'
I recently installed REW V5.18 Beta 8, running Java 1.8.0_102 32-bit on Windows 10 and am getting unreliable performance in REW and it seems to destabilize windows.
This is the first time I have ever installed and.used REW.
Steve
After initially experiencing the difficulties described below I downloaded the most recent audio driver, and Windows confirms that status. It does not seem to have helped.
I have managed to take readings for all channels but with very sporadic behavior. Here are some of the symptoms I have experienced:
- When in REW… every time I start REW I get the ‘system test audio generator not available’
- each time I switch to a new channel to test and press ‘check levels’ I get the' soundcard no input data' popup albeit at times there is a significant test signal…. at times not... I toggle in and out of measurements and sometimes it starts working, sometimes not
- Each time I use REW then try to restart the surface PRO I get that hanging/looping in ‘restarting’ mode, and have to hold the power button for a few iterations of it attempting to restart… This only ever occurs when I have run REW since last boot
- And obviously, because I got measurements for all channels, in between these sporadic but frequent issues it does work
- When not in REW, the UMIK-1 mic and DVD playback through the Marantz 8802 are 100% reliable
Steve
