richardnew12511
- Sep 15, 2019
- Messages
- 31
Last March I tried for months to get Audiolense working for my 7.2.4 channel system(mitchco was gonna do the calibration), but I eventually had to give up. I wasn't ever able to get a successful measurement. I tried with 3 different Windows 10 machines, and two different AVRs(Denon and Yamaha), and got the same error("sound card is not supported"). Pretty certain windows playback device settings were all setup correctly, as well as ASIO4All settings. You can read more about my struggles here(if you want). The only 2 things that were common between all 3 windows machines and both AVRs was 1. HDMI, and 2. ASIO4All, so I'm thinking the problem is there. Note that ASIO4All sucks majorly for Roon listening too. It works perfectly for about 45 minutes, but then a scratching sound starts occasionally popping into the music. The scratching sound becomes more and more common until I restart the machine, at which point it works again for 45 minutes.
I'm ready to try going at this problem again. This time I want to start from scratch. I'll lay down my needs and wants, and maybe you guys can guide me towards some purchases that will meet those needs/wants.
Needs:
- Audiolense correction for at least FL/C/FR and subs.
- Ability to add delay to channels that Audiolense doesn't correct(they mostly play reverb, so I'm not super concerned with EQing them)
- Auro3D upmixing
Wants:
- Video and Audio output: The windows machine is running double duty for both video and audio. I'm typing up this post while listening to music on the machine via Roon. This is why I went for HDMI, as it's the only output I know that supports video and audio. I'm willing to give this up, though. If it will only work with USB out, I can control the roon server via an IPAD, and then switch back to HDMI when I need to use Windows. Unfortunately, my current AVR doesn't support USB in I don't think(Denon X440H), but I'd be willing to purchase a new one that does.
- EQ for all 11 channels. As far as I know, this requires ASIO4All or HDMI 2.1. I don't know any AVR with 2.1 support, and I'm super skeptical I'll ever be able to use ASIO, so I'm willing to let this go too. 95% of my listening is stereo upmixed with Auro3D, so the surround/height channels mostly just play echo noise. If I can get the front 3 channels and both subs EQed, I'm thinking I can use a miniDSP down stream to time align the other 6-8 channels. I think HDMI 2.0 supports this(without ASIO)?
Needs:
- Auro3D upmixing
Wants:
