SPL tolerance curve definition possible?
Karsten42
Dear Experts,
I would like to define an upper and lower tolerance curve in the SPL graph to check if the measured loudspeaker is within given tolerance. Best will be a PASS/FAILED hint if the measured device is within or outside the given tolerance.
Is this possible with current SW release? Is it planed? What can I do to implement it?
Furthermore the release V5,19 need a mouse click only to start the measurement. The version before was easier to start with "CTRL+M + ENTER". Is it possible to fix it?
Best Regards
Karsten
I would like to define an upper and lower tolerance curve in the SPL graph to check if the measured loudspeaker is within given tolerance. Best will be a PASS/FAILED hint if the measured device is within or outside the given tolerance. Is this possible with current SW release? Is it planed? What can I do to implement it?
No plans for QA features at the moment.
Use the space bar instead of enter.
Karsten42
Dear John,
Thanks a lot for your fast answer. Using Space bar make thinks quite more easier!
best regards
Karsten
