champagnecharly
- Sep 10, 2019
- Messages
- 4
Hello,
I have a couple of spl meters running through a digirack2. i have only done a simple calibration with a field calibrator as noise source. 114db. what i find is if post calibration i turn on the calibrator/ monitor noise it produces the software will give accurate readings. however once the device is removed and monitoring normal noise levels there is a considerable discrepency between rew results and thoese on the device with rew not going below 50dbC(f) any ideas why this would occur? I read calibration files are for offfset on frequency bands however i cant see how this would cause the rew readings to be so high. any thoughts?
