Hey !
So - I've spent a few hours reading every related forum post and testing various settings in REW, to no avail ; hopefully someone will be able to help
Problem: REW's SPL meter is way off (and digits are red, indicating a lack of calibration) despite having an individually calibrated USB mic with a "Sens factor" line in the cal file, which if I understand correctly means I don't need to do any SPL calibration.
Note: I don't have a SPL meter to compare with but my ears tell me REW's SPL meter can't be right, which is confirmed by measuring the voltage at my loudspeakers' terminals when playing a 1kHz tone and comparing with the loudspeakers' sensitivity specs (in that case, 85dB @1m for Kef LS50s passive). The difference isn't small - eg. 20-30dB.
My setup:
- OS: fedora 36 x86_64, gnome.
- REW: 5.20.9, also tested with 5.20.11 beta, both with the bundled JRE.
- Omnitronic MM-2USB USB microphone with individual calibration, bought from Hifi Selbstbau
lsusb shows the mic as 'ID 0d8c:0134 C-Media Electronics, Inc. Usb Microphone'
Starting with a clean install of REW and wiped prefs.xml:
- Selecting 'Microphone [plughw:2,0]', with the 'Mic (Mic)' input (the other settings are default - I haven't changed anything else):
- Define the calibration file:
the calibration file's first lines are:
clicking on the wheels icons shows:
roomeq_wizard0.log.txt (full file attached) shows the following, which seems to indicate that the sensitivity value is properly parsed:
- As far as I understand the few settings above should be enough to be able to do calibrated SPL measurements, but the SPL meter's digits stay red + the measurements are off by a huge margin (in the picture below it should be around 67dB according to the speakers' sensitivity and measured voltage):
FWIW: REW (re)sets the input volume in the soundcard pref tab, as well as OS-wide (pipewire) volume when starting ; I've tested with setting the mic's volume both to 0 and max in gnome before starting REW, and after starting REW the volume is set to a kind-of middle value:
While doing SPL measurements, changing the os-wide volume changes the SPL values. With the new beta (5.20.11) mentioning directly accessing alsa devices I thought REW would access the mic directly (ie. bypassing pipewire) but that doesn't seem to be the case.
Any idea ? It could be linux-specific but I don't have a Windows machine to test on; however even if pipewire ends up being the culprit, why are the digits in REW's SPL meter red when using a calibration file, instead of white ?
Thanks !
(and obviously thanks to @John Mulcahy for this great piece of software )
My setup:
"Sens Factor =-17.987dB, SERNO: 7034567"
10.00 -7.05
10.59 -7.32
INFO: Mic sensitivity -17.987 dB for serial number 7034567 from MM2USB_BZ_90d.cal
Thanks !
