REW Beta Release Special use case: Voicemeeter Banana/EAPO + HDMI + UMIK 1
Justanick
Hello,
I have a computer with Voicemeeter Banana/Equalizer APO which is connected to an AVR via HDMI. The standard Audio Output on Windows is set to Voicemeter ASIO Input.
So far everything works fine.
Now I want to use REW to measure my 5.1 speaker setup. What I can do is: Set the driver to "ASIO", select "Voicemeter ASIO Input" as a device. Using the generator feature in REW I can get the speakers to output sound.
But I can only select the 8 input/outputs from the HDMI connection, but the UMIK is not listed as a an input channel.
What I couldn't figure out: How do I get the UMIK to work?
Greetings,
Mike
ASIO is essentially a single device protocol, a workaround is to use something like ASIO4All or FlexASIO to provide an ASIO wrapper around an aggregated set of devices. Use of ASIO4All is described in AustinJerry's guide.
Justanick
Thank you. I was worried, that VB's ASIO driver will collide with ASIO4All, but I will try it out :)
Justanick
ASIO4ALL was the way to go: Simply select ASI4ALL as the driver. In the driver configuration you can pick both the UMIK and VB ASIO.
Thanks again :)
