Same problem, 2 different laptops
jmtenthusiast
Denon 1911
Inuke 3000dsp
Sony
Monoprice PA-15"
Monoprice PA-15"
Polk M-30
Molk M-20
Big Marty cabinet loaded with two 1260's (2 each)
Polk M-60's
Epson
120" AT
Trying to get REW initialized for the first time.
When I set up the sound on windows playback devices, it shows 7.1., and it shows my Denon 1911. I am able to send a test tone to each speaker and sub. But when I use the signal Generator in REW, the sound only comes from the laptop speakers. REW is showing 6 channels but only 1 and 2 are active and those are the laptop speakers, left and right.
This happens on both of my laptops, one is running win7 and the other is win 8.1. I must be overlooking a "check box" or something.
One other question. My best running laptop with win7 is a 64 bit system. I am using REW32 with jre, should I be using REW64 and downloading Java 8 manually? I'm unclear, it seems as if the REW64 bit is only for Windows 10?
Which REW version? Are you using ASIO drivers, e.g. ASIOI4All? The Windows JVM only supports stereo output pairs, it doesn't directly offer multichannel outputs, easier to use ASIO.
There is no particular need to use the 64-bit JRE, the version with 32-bit JRE should work well on 32-bit or 64-bit systems.
jmtenthusiast
Denon 1911
Inuke 3000dsp
Sony
Monoprice PA-15"
Monoprice PA-15"
Polk M-30
Molk M-20
Polk M-60's
Epson
120" AT
REW version 5_19 with jre, 33,620kb downloaded
ASIO4ALL
I am selecting ASIO4ALL. There are 6 Audio Outputs. Strange to me because I have a 7.1 and therefore would expect to see 8 audio outputs. The first two HD Audio outputs 1 and 2 are playing through my laptop speakers.
If I select Java instead of ASIO4ALL, I can get signal generated to the front LR, L, R, or L+R.
jmtenthusiast
Denon 1911
Inuke 3000dsp
Sony
Monoprice PA-15"
Monoprice PA-15"
Polk M-30
Molk M-20
Polk M-60's
Epson
120" AT
