RTA screen is missing distortion measurements
bcodemz
Hi John,
I noticed that in this version of REW the distortion panel in RTA doesn't work anymore. Previously I've found that panel to be very helpful in identifying the loudest frequency of the audio I currently capture. I hope you can bring that back.
Thanks, it will work again if you open the signal generator, you can close it afterwards. I'll fix that for the next build.
