Rew 5.20 Beta 29 stuck on "adjusting clock rate" on OSX
oliver
Italy
Hi John,
I do have updated to the last REW release on my macbook pro 10.13.6.
I do have two different Scarlet 2i4 audio interfaces set to 96Khz. Before the update (5.20 Beta 28 version) everything was working, now when I try to make a measurement REW get stuck to "adjusting clock rate":
If I close this window REW become unrensponsive and I do have to close it and start it again, and get stuck again when I try to make a measurement.
This are my settings:
Thank you.
Oliver.
Try turning off the Analysis preference to "Adjust clock with loopback". I will investigate in the meantime.
Please check the log files to see if anything has been captured, easiest is to zip the REW directory in ~/Library/Logs and attach it here.
Edit: never mind, I have found the problem and fixed it for the next build. Leave "Adjust clock with loopback" unselected until then.
oliver
Italy
Hi John,
leaving "Adjust clock with loopback" it works, thanks.
Just a small question on the new "invert polarity" option. Is a great feature, is there an indication when the polarity is inverted? Is a bit hard to remember which one was the correct one.
Thank you.
Oliver
The check box in the Impulse graph controls shows the state. I could use a check box on the SPL & Phase graph as well, or perhaps a toggle button.
