REW 5.20.9 does not start under Raspberry Pi
Eddie6411284
Hello everyone,
I hope you can understand me. My English is not the best.
I am using a Raspberry Pi400 with a 64 bit Version of RaspiOS Bullsey from 04.04.2022.
After installing JDK 8 update 202 i was able to install REW 5.20.0 from here: roomeqwizard.com (Sorry, no links allowed in my first posting)
But I can't start REW. There is an error in roomeq_wizard0.log.txt and I don't know how to fix it.
Aug 15, 2022 2:19:22 PM roomeqwizard.RoomEQ_Wizard A
SCHWERWIEGEND: Error during startup java.lang.reflect.InvocationTargetException
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1349)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1324)
at roomeqwizard.RoomEQ_Wizard.main(y:3411)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:84)
at com.install4j.runtime.launcher.UnixLauncher.start(UnixLauncher.java:69)
at install4j.roomeqwizard.RoomEQ_Wizard.main(Unknown Source)
Caused by: java.awt.HeadlessException
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:204)
at java.awt.Window.<init>(Window.java:536)
at java.awt.Frame.<init>(Frame.java:420)
at java.awt.Frame.<init>(Frame.java:385)
at javax.swing.SwingUtilities$SharedOwnerFrame.<init>(SwingUtilities.java:1763)
at javax.swing.SwingUtilities.getSharedOwnerFrame(SwingUtilities.java:1838)
at javax.swing.JWindow.<init>(JWindow.java:187)
at javax.swing.JWindow.<init>(JWindow.java:139)
at roomeqwizard.$B.<init>(y:1194)
at roomeqwizard.RoomEQ_Wizard$1.run(y:817)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:301)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
SCHWERWIEGEND: Error cause: null
Can anyone help me please?
Regards
Eddie
Looks like you have installed a headless JRE, which means no support for a display, keyboard or audio. Install a full JRE.
Eddie6411284
Its the only Version I got for an ARM 64 CPU.
jdk-8u202-linux-arm64-vfp-hflt.tar.gz from oracle.com...javase8-archive-downloads.html
