Sonnie Parker
- Main Amp
- Additional Amp
- StormAudio PA 16 MK3
- Other Amp
- Music Server
- ROON Nucleus One
- Magnetar UDP800 UHD Player
- Streaming Equipment
Lenovo X1 Carbon
- Turntable/Cartridge
Ortofon 2M Blue Cartridge
- Streaming Subscriptions
- Lifetime Roon Subscription
- Other Equipment
Zero Surge 8R15W-1
Zero Surge 2R20W
- RTJ 410
- Front Wide Speakers
- JTR Noesis 110HT
- Center Channel Speaker
- JTR Kallos (Custom Built)
- Surround Speakers
- JTR Noesis 210RT
- Surround Back Speakers
- JTR Noesis 210RT
- Front Height Speakers
- JTR Noesis 110HT-SL
- Middle Height Speakers
- Rear Height Speakers
- Bass Shaker System
- Dayton Audio BSA-200 Amp
4 BST-1 Bass Shakers
- Other Speakers
- Wharfedale Super Linton
- Video Display Device
- Sony 98X90L
- Remote Control
- URC MX-890
- Cables
- AudioQuest - Various
THX PixelGen HDMI
Pangea Power Cables
Blue Jeans Cables
SVS Soundpath Cables
Custom Cables
- Satellite System
- None
- Other Equipment
- Network/Internet
- C-Spire 1Gig Fiber
Omada OC300 Controller
Omada ER8411 10G Router
Asustor Flashstor NAS
- Headphones/IEMs
- HIFIMAN HE1000se
Unique Melody Mest MKII
- Headphone DAC/Amp
- Eversolo DMP-A6
RME ADI-2 DAC FS
HIFIMAN Goldenwave Serenade
- Whole House System
- HEOS System
Home-150 Speaker x6
Samsung S9 Tablet w/ HEOS
- Office/Study System
- Office System
Dell Precision Computer
Roon Networked
- AV Test Room System
NAD M33 Streaming DAC Amp
MartinLogan Motion XT F200
JTR Captivator RS1
miniDSP EARS
Zero Surge 8R15W-1
Zero Surge 2R20W
Dell Optiplex
Roon Networked
- Additional Room System
- Sunroom System
Zu Audio DW-6 Speakers
Roon Networked
Dish Joey
JVC 37" TV
- Cabin System
Onkyo TX-SR805 Receiver
Infinity Primus P163 Speakers
Shield TV Pro
Sony 55" TV
- Vinyl Room
Technics SL-1210GR2 Turntable
KLH Model Three Speakers
Zero Surge 8R15W-1
- Barn Jam
Soundfield Custom Speakers
I having a fellow build me a amp testing load for 2/4/8 ohm testing. It will be similar to the smaller tank you see below... which is about 20 gallon. It will be filled with RV antifreeze. I spoke with Pat Brown who built these for testing pro audio and car amps. He has tested amps rated up to 10,000 watts. He says the temps have never really gotten remotely hot and he uses mineral oil.
At any rate... each element is 8 ohms (measured/tested with an ohm meter). I believe I will need 8 of these wired so that I can use jumpers to come up with the appropriate 2/4/8 ohm loads. However, I'm struggling wrapping my mind around the correct wiring from each element to the speaker terminals.
If I wire each element to one set (+/-) of terminals... we have 8 ohms on that terminal, and we will have 8 speaker terminal sets total. I suppose I can daisy chain the terminals from the back to the next terminal. Then use jumpers to get to 4 ohm or 2 ohm.
Can anyone draw me up a diagram/schematic of the how this would all need to be wired, then how the jumpers would need to be wired to accomplish each load?
I guess I would get out my handy dandy digital volt/ohm meter and double check the measurements at each heater element and then at the corresponding terminals... Once each set of heater element and corresponding terminal checks out, I would then do as you say above, measuring each step of the way from 8 ohms, 4 ohms and 2 ohms... Only if everything is within some reasonable spec would I attempt to connect an Amplifier worth more than about $25 to the thing for the first time... Wear some eye protection and keep a fire extinguisher and some thick rubber gloves handy...
