Hey all
New member here.
I recently took all my treatment out of my room to make a measurement. I want to start from scratch as I think some of the treatment is causing problems.
Could someone take a look at my mdat and tell me how bad things are? I see the obvious dip at 120 but otherwise it looks ok ? Obviously with no treatment in - the reverb time will be terrible.
Any help and advice much appreciated. I'm happy to spend out a bit on specific problems and happy to DIY easy stuff. I am in the UK.
My room is an ok size but the ceiling is low.
203cm high
303cm wide
466cm long
Thank you
Joe
New member here.
203cm high
303cm wide
466cm long
Thank you
Joe
