JOSE BEMBIBRE
- Jul 17, 2018
- Messages
- 10
Hi,
After a merge of near field with a far field measurements, the IR window is the one of the far field, hence if you want to see the SPL full span you must adjust the IR window to the near field width.
I am not sure if this behaviour is deliberate or is just a small bug, anyway IMHO is confusing. I would suggest either applying automatically the IR window of the near fiel or a warning.
Best.
José
Best.
José
