Sure, lots of people. There are many ways to approach ProFi (what I call it). You can just do it with any consumer amp or whatever, or get active units and use your phone. Simple and something, not sure what it will be, so many variables.
The advantages of pro speakers is they handle power, not in the sense of play them at 150 db, but in the sense that they can have live sound dynamics (odd that...). So, IMHO, that is what you want them for. Consumer amps of any sane (to me) price, er, just might not deliver the mojo that really does it. For that reason I suggest active or use pro amps, unless of course, you can float many K for fancy audiophile stuff.
PA speakers are pretty capable and can really rock... but there is also the path of using pro drivers and making your own HiFi cabinets or Baffles for them. This would be the route I went, pro drivers, crown amps, my acoustics (baffles, diffusers etc) and the best HiFi input signal I can put together for it (in my budget etc). The results are everything I was hoping for, instruments sound like real instruments, vocals are honest, everything is just dead on hones, what a good pro system should be, flavor is up to the person making the input, in home audio that means the turntable/cartridge/preamp... dac... tubes... cables... power, all the audiophile HiFi tricks count big and, being pro gear, eq and stuff (you don't have to be uptight about NO EQ! screamed the audiophile... pro gear is made to be shaped to what you want, IMHO)
There are also -very- high end pro speakers for the mixing mastering setups, like ATC... used quite often in high $ home setups. Smaller near field monitors are often used for computer setups...
IMHO pro gear category has a ton to offer....
edit- I'll add that my ProFi setup does great at all sound levels, from about 45db at listening position up to anything that peaks out at, say, 120 db, but no sane human would do that for long, that said, it's been a life long goal of mine to have a rig that when I want to truly bathe in the sound and turn it up, the system does not lose any magic at all, but in fact just keeps getting better and more epic, and I mean really freaking epic, and I finally have that with the ProFi, so don't freaking listen to anyone telling you it's a bad road, go down that road for yourself and see what you hear, but keep in mind, it's the HiFi details and qualities of sound that you feed it that is so important to the results of your ProFi setup, and, Acoustics Matter!!!!... I'll also add that I tried my near field studio monitors for general room use, that kinda range, like anything else in the vast range of pro audio gear, is gonna be speaker specific.
