REW doesn't have enough resolution to measure the distortion of my motherboard soundcard at 80% volume, even using the 4M sweep. I cannot use multiple sweeps as they interfere when summed presumably due to clock drift. I can clearly see harmonics in the RTA which reports them correctly. I can accept much longer sweeps if that is necessary.
Furthermore, REW displays 16 bits in the lower left, are sweep measurements done at 16bit resolution?
