Hi,
I´m trying my first SPL measurements with REW (version 5.9 on Mac OSX 10.9.5) I have the following result with a Near Field measurement. As show the frequency range for phase values is more limited than the range for SPL values. Some explanation for this?
Thanks in advance.
Best regard.
José
Download 5.19 again and re-install it, then do "Apply Windows" (in the IR Windows dialog). The initial build had a bug that was fixed a couple of days later.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
