cwood
- Jul 26, 2021
- Messages
- 5
- Yamaha 1040
Hi all
Downloaded latest version and installed along with ASIO following the REW 101 Getting started guide.
I am getting a freeze up on start and the following errors when I use the configuration area. I had been able to get through most of the ASIO config and it was seeing my AVR etc but eventually wouldn't even start. This is the current error.
Any help or suggestions appreciated.
REW V5.20.3 running Azul Systems, Inc. JRE 1.8.0_302 64-bit on Windows 10 Locale: language en, keyboard US, windows-1252 at 96 DPI
Message:
Stack Trace:
roomeqwizard.E.B(y:3538)
roomeqwizard.E.D(y:1048)
roomeqwizard.TH$25.actionPerformed(y:2400)
javax.swing.JComboBox.fireActionEvent(JComboBox.java:1258)
javax.swing.JComboBox.setSelectedItem(JComboBox.java:586)
javax.swing.JComboBox.setSelectedIndex(JComboBox.java:622)
javax.swing.plaf.basic.BasicComboPopup$Handler.mouseReleased(BasicComboPopup.java:868)
java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
java.awt.Component.processMouseEvent(Component.java:6539)
javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
javax.swing.plaf.basic.BasicComboPopup$1.processMouseEvent(BasicComboPopup.java:517)
java.awt.Component.processEvent(Component.java:6304)
java.awt.Container.processEvent(Container.java:2239)
java.awt.Component.dispatchEventImpl(Component.java:4889)
java.awt.Container.dispatchEventImpl(Container.java:2297)
java.awt.Component.dispatchEvent(Component.java:4711)
java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
java.awt.Container.dispatchEventImpl(Container.java:2283)
java.awt.Window.dispatchEventImpl(Window.java:2746)
java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
java.awt.EventQueue$4.run(EventQueue.java:733)
java.awt.EventQueue$4.run(EventQueue.java:731)
java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
Message:
Stack Trace:
