Nube - sound card suggestions
Tom Richards
Looking for input.
Trying to put together a measurement computer from a "hand me down" dell Optiplex 760 computer
Running Windows 7 with NO sound card. Link to computer specs:
http://www.dell.com/us/dfb/p/optiplex-760/pd
Any one have suggestions for a sound card that will work in the PCI slot available ?
Top end of my budget is $100 US.
Any help appreciated
Tom R
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
I don’t know if you’ll be able to find a PCI soundcard that will accept a professional measurement mic, which requires an XLR input with phantom power. Your best bet is a USB sound card like the one AudiocRaver recommended, or even a USB measurement mic.
Tom Richards
Thanks to you and Audiocraver for the responses. I will look into these options further. I also have to get some help with this computer - make sure it is fully functional for use with REW.
Will regroup and get back with you.
Thanks,
Tom
Tom Richards
Thanks,
Tom
Wayne and AudiocRaver
Update: I picked up a mini DSP USB mic and have been able to perform frequency sweeps, but having trouble setting up, calibrating, and getting proper impedance sweeps.
Doing a little networking I have found access to a Focusrite Scarlett Solo 2
I see it listed in the REW site to use with other non USB/powered mics.
It looks very similar to the "Tascam" unit suggested ?
I am primarily a two channel guy, interested in speaker building and room acoustics.
Will the Solo do what I need ?
Looks like:
USB mic input to computer
REW driving the process,
USB out to Solo, then use the "monitor" section of Solo to drive speaker for testing ?
Please advise,
Tom R
