Dotcom1970
- Jun 16, 2021
- Messages
- 1
Hi there, newbie from the UK, been lurking for a bit so this is my first post.
Planning my install and was looking for the best way to program my Helix DSP Mini.
I looked at the Helix MTK1 RTA, but the price was outrageous for something that is likely not to be used often.
Looking at some pictures, I noticed you could get the microphone and USB Mic plug adapter from different suppliers at a fraction of the cost!
I purchased an identical Behringer ECM8000 and a T-Bone USB Mic Plug from thomann.de for just under £70 as opposed to £330!
I was then puzzled how to best position this in the vehicle when I stumbled upon these two items:
ebay item 284146427799
amazon item B075XMB32W
When combined, they fit perfectly the mic holder supplied with the ECM and then allow you to attach the microphone to the headrest mounts and give you enough flexibility in positioning to make all the various measurements.
So for roughly £80, I've got a complete, flexible measurement system
Hope this helps other users looking for a similar solution.
(The above links are from UK suppliers, but similar items available from Aliexpress etc.)
