juggler
- Jul 12, 2022
- Messages
- 2
- Marantz SR6012
- Main Amp
- Rotel RMB-1085
- Additional Amp
- Emotiva A500
- Sony UBPX700
- Emotiva T1
- Center Channel Speaker
- Emotiva C2
- Surround Speakers
- Polk in-wall
- Surround Back Speakers
- Polk in-wall
- Front Height Speakers
- Polk in-ceiling
- SVS SB2000 and SVS SB12-NSD
- Other Speakers or Equipment
- minidsp 2x4HD
- Video Display Device
- Vizio LED
- Streaming Equipment
- Fire Stick 4K
I'm brand new to REW and minidsp and am looking for some help integrating 2 subwoofers. I'm still stuck on trying to measure an accurate sweep on the first subwoofer using a Umik-1 and minidsp 2x4HD. My main question is why I'm not seeing or hearing frequencies below about 60 Hz.
When I level-matched with pink noise, I had to turn the gain dial on my sub about 75% to the max just to get 75 db and turn my receiver's main volume to -15 (I usually listen around -20). When I go to measure in REW, I'm not getting any output below about 50-60 Hz, then there's a sudden jump around 80 Hz (see attached curve). I assume I'm missing some sort of crossover/filter setting. My room isn't very big, but the back wall is only a waist-high wall and it opens up to a much larger part of the basement. So it's a difficult room, but in the past when I've just been running Audyssey XT32, and then tried test tones at 20, 30, 40 Hz..., I've heard my sub generate these frequencies pretty well.
I used all the same settings that Home Theater Gamer recommends in his minidsp tutorials. In minidsp, I have the output crossovers set to "bypassed". Receiver settings: Audyssey XT32 is turned OFF, all crossovers set to 250, "bass" set to LFE with 120 Hz LPF, sub trim level set to 0, sound mode set to "stereo". I noticed test sounds still coming from the front L and R speakers, so I turned off my external amp that powers those speakers.
Thanks for your help!
