MiniDspHD and Harmony Hub
JStewart
Central FL
The minidsp doesn’t have on/off function
Adding to Harmony for other functions is a little convoluted.
Step 1: add one of the brands found on Section 9, page 48 of the 2x4HD OM here https://www.minidsp.com/images/documents/miniDSP 2x4 HD User Manual.pdf#page48 to Harmony as a device. Pick any model for the brand. Choose a brand you don’t already have on your Harmony to avoid conflicts with the IR codes.
Step 2: follow instructions for the minidsp to learn the codes for the device using the new device in Harmony
Step 3: add the new device in Harmony to Harmony Activities you want to use the minidsp.
That’s how it’s done, but I’ll add that if your using the minidsp for sub to sub alignment then there will be no need to change anything after it’s set up. .
