bowl_actually
- Mar 4, 2020
- Messages
- 29
I have a set of small speakers and a small sub that I use to take to other places to do room analysis. I have used them for friends and clients who build rooms, some times in new houses or spaces where they don't yet have speakers installed to do some pre-work on the room.
For these measurements, I would like to "remove" the speaker signature similar to how we remove the soundcard and mic signatures. That way I get only the response of the "room" and not the "room + speaker."
I thought about trying to use the "house curve" but I think that's only applied to the filter section.
Is there a way to load in a "speaker calibration" if I know the response of the speakers I'm using to test? I guess I can load the speaker correction curve in EQ APO or some other systemwide EQ as long as I use the java version and not ASIO. Anyone else ever done this?
