REW Beta Release Measurement shortcut no longer works
TimWaldron
In the last couple of releases the Cntrl+M then ENTER shortcut no longer works. Control + M works but you cannot any longer jst press Enter to start the measurement. Please can this be fixed? Thanks for a superb product!
Space bar will activate the button that currently has focus. The enter key is used when a window has a default button defined, but it is a little risky as it activates the default button even if another button has focus, which may not be expected behaviour, so most REW windows do not have a default button defined.
TimWaldron
Ah brilliant! Thank you very much for your swift reply. much appreciated.
